Glennard,
From Longtooth's post on the subject:
"Removal:
1. Back off screw plug [that's the 22mm screw on top] about 2 turns, unscrew hexagon screw with spigot [that's the 10 mm screw on the side], and by inserting a screwdriver between the screw plug [22 mm plug] and the cover disk [cover disk is first item directly beneith the screw plug], and push out the pressure piece upward. [pressure piece is the the large cylinderically thick bronze/aluminum piece, referred to in previous posts on this thread as "bushing" ]"
He describes the way to essentially prise the bushing up by using the screw plug, still attached but loosened, and a screwdriver. Sounds a little risky for you with everything stuck. Sort of like the advice my father gave me once, after running a "yellow" traffic light, which was: "Son, I don't normally drive like this...and neither should you".
g
