Author Topic: Indicative Revs at 60MPH  (Read 8925 times)
GregSoz
« on: July 10, 2007, 04:39:04 »
Hi Guys,
have just purchased a 68 Auto 280SL and want confirmation that the gearing is correct ie that the car is in 4th as it SEEMS to rev high around 3100RPM at 60MPH. I know they are high reving but is this OK?
Also is it OK to run PREMUIM PULP (above 95 octane) with no lead additive?
thanks
Greg from South Oz Australia
Re: Indicative Revs at 60MPH
« Reply #1 on: July 10, 2007, 05:15:45 »
Hi Greg,
Welcome aboard. Any pics?
Yes to both your questions. The revs are spot on.
You will get used to the noise level of the engine.
I was told to turn my radio up, but the speaker is so old. I actually like the sound of the engine now.
The search function works very well. So if you have any questions about your car do a search. Most topics have been discussed in depth but we always welcome a challenge.
Because of the differences in the models of our cars, a lot of people have their cars model and year in their signature. This helps responders provide specific information to your car.
cheers
« Reply #2 on: July 10, 2007, 07:03:12 »
To be accurate you need the following information.  Rear axle ratio-stamped on the differential-should be 3.69 or 3.92 and your tire diameter.  Final transmission gear ratio is 1.00:1.
These programs will help.  Figure the tire diameter and then input the info into the rpm/mph calculator.
http://www.1010tires.com/TireSizeCalculator.asp?action=submit
http://www.angelfire.com/fl/procrastination/rear.html
« Reply #3 on: July 10, 2007, 08:21:32 »
Greg
Allowing for 40 year old error - and accepting the advice below - yep. Sounds about right.
Do a search on the site for RPM but mine runs:
3000rpm - 60mph
3500 rpm - 70mph
4000rpm - 80mph
and this afternoon
4500rpm - 90mph
Mine was built in '69
And I was also told when I bought mine that MB over specced the valves etc such that they run perfectly well on unleaded. Mine has never been converted as such and runs all day, very happily, on 94/95 octane unleaded. Sometimes as a special treat, 98
GregSoz
« Reply #4 on: July 12, 2007, 04:14:17 »
Thanks Guys,
greatly appreciated. Will post some pics on the weekend, only picked it up Monday night and haven't had the joy of taking for a spin/photo in daylight hours.
GSoz
« Reply #5 on: July 12, 2007, 06:25:10 »
Speed = rpm/50???  Depending on diff. ratio, tranny, tires, etc.  Or 50 times speed(in mph) equals rpm.  50 might be 45 to 55.  Important thing is mpg.
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« Reply #6 on: July 12, 2007, 09:13:11 »
Hello Greg - - Yes, you have correctly determined that our 113's are geared way too low.  This is so because of a flawed decision back in the early development of the car.  MB wanted their new  vehicle to have fast acceleration because the other cars in its performance/price class were the Jag XKE , and the Corvette ( both of which will unquestionably leave our cars behind in a cloud of tire smoke ). There are two remedies: Live with it - -  or replace the rear end with a  3.27 ratio  from a 280 SEL 4.5. My 230SL has this set-up and I am very happy with it. Fortunately for me one of the previous owners had this done years ago. Regards, Larry in CA
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
« Reply #7 on: July 12, 2007, 10:14:26 »
lurtch,
So how many MPH do you get per 1000 RPM?
« Last Edit: July 12, 2007, 12:01:28 by naj »
lurtch
  • " ICON 66 "
« Reply #8 on: July 12, 2007, 18:30:14 »
Hi again - - - I guess I left out a few details?
The conversion constant  with the 3.27 differential is 1.15 . - - Because I did not change the speedo gearing the indicated road speed is about 60MPH  while the true and calculated road speed is 69 MPH @ 3400 RPM.
Download Attachment: 3400-RPMs-equal-70-MPH.jpg
49.89 KB
1991  300TE (gifted)
1998  E320 (sold)
dwahi
« Reply #9 on: September 24, 2012, 10:10:11 »
Hi All
So following an engine tune I'm curious to find out more about the axle ratio my car may have.
I get 4000rpm at 70mph, is that correct? 280SL Auto
W113 280SL Auto 050G
Previous:
Porsche 968 Cobalt Blue (photos: http://www.flickr.com/photos/67828893@N00/tags/porsche968/)
VW GTi Mk VI
VW Jetta Mk II
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #10 on: September 24, 2012, 17:33:46 »
There is an older thread - "Highway RPM's " and there is a graph that shows speeds vs rpms for the different rear end ratios - its pegged mine perfectly - 3.69 rear end -   3200 rpm at 68 mph.
4000 rpm at 70 mph seems too high - Even with a 4.08 the graph says 3800 rpm at 70 mph.
There are several threads and pictures in the archives showing where to see the rear end ratio stamped on the rear end.  That may be a good place to start.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
« Reply #11 on: September 24, 2012, 19:07:46 »
Have you got a GPS thingy - as that would get yor speed spot on.
« Reply #12 on: September 24, 2012, 21:43:32 »
Use the graph in this post
http://www.sl113.org/forums/index.php?topic=16765.0 - Reply #2
dwahi
« Reply #13 on: September 24, 2012, 21:55:35 »
Great, thanks a lot. Ill go out again and then recheck the graph against my readings. Thanks a lot for your help.
Regards
Previous:
VW GTi Mk VI
VW Jetta Mk II
« Reply #14 on: September 25, 2012, 07:39:12 »
What you really need to do is get under the car and look at the flat area on the differential housing and from the stamped ratio number you will know if it is the correct one or a has been replaced with a lower ratio one.
twistedtree
  • USA, VT
« Reply #15 on: September 26, 2012, 00:35:56 »
Are both the 4-speeds and automatics 1:1 in the transmission?
1964 MB 230SL
1970 MB 280SL
2023 BMW x3
