Author Topic: Air Filter Question  (Read 7260 times)
Air Filter Question
« on: July 14, 2007, 09:49:57 »
Can any of you answer this: would replacing the standard 113 air filter with something like a K&N really have an affect on a car's performance?
I remember in my younger days, that it was the thing to do on "dirt bikes", etc. but curious if and how it would help our cars. I have a pretty new and clean (couple years) filter and things are running great. Would such a filter make a diff? Thanks.
Re: Air Filter Question
« Reply #1 on: July 14, 2007, 11:28:39 »
http://index.php?topic=5712
http://index.php?topic=2931
http://index.php?topic=1046
http://index.php?topic=953
« Reply #2 on: July 14, 2007, 13:11:57 »
Oops, I better learn to search before I leap. Moderators have my permission to delete this thread (as long as I get the following answer!  :) )...
I came away from those threads still wondering. Did anyone ever come up with a definitive part number for the K&N that fits correctly inside the cannister?
« Reply #3 on: July 14, 2007, 18:35:53 »
http://www.knfilters.com/search/product.aspx?Prod=E-2380
« Reply #4 on: July 14, 2007, 20:24:36 »
Hello James, and Naj,
Try a spin around the block with no filter at all.  If you find little difference, then even a K&N is a waste of time and money.
« Reply #5 on: July 14, 2007, 20:43:40 »
Thanks Naj and Joe. I called around -- all places will need to order the E-2380. I'll try the non-filter test first -- see what happens.
harleydan
« Reply #6 on: July 15, 2007, 11:45:11 »
A K&N filter is reusable (that is it can be cleaned, re-oiled and re-used many time over); so even though one might not notice any performance gains, at least it saves some money in the long run.
When I recently installed the K&N filter in mine, it did seem to add a little bit of performancce (maybe just hopeful/wishful thinking), but I can not quantitatively give you by how much.
On installation becasue I had to remove the air hose from the manifold throttle body, I noticed that the insides of manifold throttle body, where the throttle butterfly is located at, there was a lot of accumulated black residue/soot.  I tries cleaning it out as thoroughtly as possible (by sticking in my finger with cleaning and de-greasing solution on a small clean cloth and by opening the butterfly) when I had the air hose off.  Maybe I should have had tried taking the manifold throttle body off completely to clean it beeter.  Has anyone tried to clean this part and how did they do it?
Cheers,
Danny
1970 280SL silver Euro 4-speed
« Reply #7 on: July 15, 2007, 14:39:02 »
Well, test #1 (Mann filter vs. No filter) is in. Although it's a lot harder to tell "good to better" than bad to better, I think having no filter made some difference. A little more peppy. Maybe?
Anyway, I am going to try the K&N and will hopefully be back with test #2 (mann vs KN)in a few days!
psmith
« Reply #8 on: July 18, 2007, 23:56:31 »
Hi James,
I gleaned this from the web from an owner named Mike Haney who ran a 230SL in Carrera Panamerica as best as I can remember.
K&N Filtercharger
http://store.summitracing.com/partdetail.asp?part=868&page=2
Purchased from:
part# KNN-RE-0810
Cost: $46.95
Comments:
VERY impressed with performance increase and smooth installation,
this
particular filter seems like it was made for the 113's... simply
remove your air filter canister, cut a "U" in the neck of the filter,
to allow better airlow through the bend, put some silicone sealant
around the top of it, and slide it into the lid from original
canister. we also took some heater hose, sliced it lengthwise and
wrapped it around the lip of the canister lid, then wrapped that with
a layer of flexible pipe wrap from Home Depot", it fit in there nice
and snug and looked nice. I'll include pictures in the pictures area
of this and everything else I have that related to these items.
Overall, best $50 I spent!!!
Pete S.
« Reply #9 on: July 19, 2007, 09:29:03 »
Thanks Pete. Interesting. I remember Mike and his "rally car." The filter I ordered is a little different: its the E-2380. According to the pics and dimensions, it should just drop in. Supposed to be here today! (or maybe manana) so I'll let you all know.
« Reply #10 on: July 20, 2007, 08:16:15 »
The results are in! I received my K&N filter yesterday. It fit perfectly and I am going on record as saying I think it made a difference...
The model is E-2380. Exactly as tall as old one (Mann) -- slightly smaller diameter (which made it easier to install).
Here in CA, it is $43.95 from Kragen Auto. They had to order it (2-3 days).
harleydan
« Reply #11 on: July 20, 2007, 10:12:23 »
James,
If you can, can you elaborate on how you thought the K&N filter made a difference in the car's performance?   I too thought I felt a difference but I surely can not quantify.
Danny
« Reply #12 on: July 20, 2007, 10:43:24 »
Darn Dan. I ws hoping I could slide that past ya'all...
Well. It is purely a feel thing. My car has been running very well lately -- but when I did the switch I seemed to get a little more of a steady acceleration between say 1800 to 2400. Once above this, the car has always responded strong -- so I sense no real change there. As you said -- it is really hard to quantify short of a dyno test or something. I'd wager on some degree of improvement. It sure hasn't hurt anything!
PS -- mine is an automatic.
« Last Edit: July 20, 2007, 10:47:36 by J. Huber »
hill
« Reply #13 on: July 20, 2007, 10:59:46 »
Back in the day we dyno'd a car several times to get a base line. Water temperature was consistent and all tests were done in a 1/2 hr time frame. Stock paper was 252 hp, K+N was 254 freshly oiled and no filter was 257. The process was reversed with the same results. This of course did not factor in any ram air effect since big blowers were not available. The reason I like the washable is cost, my 350 sl has 260M on the clock and has blowby. If I had to change paper filters every month $$$ :evil:  HP gains were negligible in the lower to mid range RPM 1000-6000 RPM and really only came up in the 7000-11000 range (rotary).
Happy Benzing
Darryl, Hill
350 SL4.5 #60
1967 250sl "California"
psmith
« Reply #14 on: July 20, 2007, 14:06:37 »
Hey James, with your K&N filter and black wheels like mine, yours is almost a rally car!  Add some headlight covers and some stickers and you're there!  :mrgreen:
Pete S.
« Reply #15 on: July 20, 2007, 18:40:17 »
Hey Pete, I'm closer than you think....
http://www.sl113.org/forums/uploaded/J.%20Huber/2007410026_rally2.JPG
psmith
« Reply #16 on: July 20, 2007, 23:42:26 »
All you need are some rally decals from this guy.
http://stores.ebay.ie/I-Say-Ding-Dong-Decals-Stickers
Pete S.
