Author Topic: how not to change an alternator 66 230  (Read 2072 times)
merrill
« on: July 20, 2007, 16:22:47 »
so, found out today the hard way to change the alt. after disconnecting the wires, I unbolted the adjuster and removed the belt and left the adjuster clamp in the car AND I then removed the long pivot bolt from the alt / mounting bracket.
then all sorts for washers and spacers fell out.
next time , just disconnect all the wires, fan belt and leave the adjusting clamp / nut on the alt.  then remove the 2 bolts from the bracket and all is much eaier to get to and re assemble.
matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Rolf
Re: how not to change an alternator 66 230
« Reply #1 on: July 20, 2007, 18:44:10 »
OPPSIE
Rolf
1966 230SL Auto
1992 300D
1991 FLHS
