Author Topic: Best adhesive for door sill mat replacement  (Read 2802 times)
bmitchell
« on: August 08, 2007, 13:52:45 »
Hi-
Im replacing the inner and outer door sill chrome / aluminum and the 4 inch grey / black mat on both the drv and passenger sides of my 280sl.
Suggestions on what adhesive to use to adhere the new mat material.
and as a bonus question what adhesive are folks using for the water seal gasket around the trunk.
thx
brett
dldubois
  • USA, FL, Pembroke Pines
Re: Best adhesive for door sill mat replacement
« Reply #1 on: August 08, 2007, 20:04:21 »
When I replaced my threshold mat I just used regular old contact cement available at Home Depot.  I put on two coats and its held well.
When I reinstalled my trunk seal (and all other seals) I just used a 3m weatherstrip adhesive available at any auto parts store.
Dana
« Last Edit: August 08, 2007, 20:05:17 by dldubois »
Dana DuBois
1969 280sl
Pembroke Pines, FL
« Reply #2 on: August 08, 2007, 20:54:57 »
Make sure to buy one that holds up at high temperatures - a car sitting in the sun can get really hot!  I like DAP/Westwood "Gel formula" since it doesn't drip, and you can adjust the pieces for about 30 minutes.
« Last Edit: August 08, 2007, 20:55:30 by 66andBlue »
sjiatrou
« Reply #3 on: August 08, 2007, 21:23:43 »
This may sound unorthodox, but I did not glue mine down.  I cut my own mat to fit snuggly between the chrome rails so it doesn't slide or bunch.  I "open and inspect" underneath the mat every now and again to make sure nothing bad is happening under there.  At least this way I know that no stray moisture is building up and doing nasty things to my door sill.
Steve Iatrou
Seaside, CA
1964 230sl roadster
White (050)/Black (116)
bmitchell
« Reply #4 on: August 09, 2007, 07:19:18 »
thanks guys-
the contact cement was my initail gut feel - will take the heat issue into consideration in product selection
b
