Author Topic: big problem with axcel refiting please help??  (Read 2599 times)
erickmarciano
  • Canada, Quebec, montreal
« on: August 08, 2007, 19:50:06 »
Folowed Joe's great post on how to remove the axcels and all went well . But now it is very hard to put the right axel back in as I hit the hub with a hammer the bearing starts to twist I can not push it in with out the bearing going more in on one side  .put the axcel in a frezer over night so the bearing with be smaller with the cold<this works for Vespa crank bearings>.and ideas??
thanks
Erick
2004 Volvo V70-R
1971 280sl
1962 VW bug
1971 Harley FLH
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: big problem with axcel refiting please help??
« Reply #1 on: August 08, 2007, 20:35:56 »
Hello Erick,
The barrel roller bearing on the right side is always a bit tedius. As you have found out it will tend to swivel out of alignment. Try scraping the sharp corner of the axel housing with a utility knife to chamfer its sharp corner of the axel housing opening. This should help start the bearing.
It usually takes repeated attempts on the right side. Be patient.  I like your idea of freezing the axel and bearing to help.
erickmarciano
« Reply #2 on: August 08, 2007, 21:17:02 »
Thanks Joe
I can't get the axle tube perfectly straightwith the jack . I think I feel  the clip catch before the bearing starts to go in? does that mean the angle is good?one last thing for now , to get the axle in should I use good force on it with a hammer?
thanks so much
2004 Volvo V70-R
1971 280sl
1962 VW bug
1971 Harley FLH
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
erickmarciano
« Reply #3 on: August 09, 2007, 22:09:03 »
the freezer did the trick
thanks
2004 Volvo V70-R
1971 280sl
1962 VW bug
1971 Harley FLH
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
