Author Topic: Gasoline  (Read 3620 times)
Gasoline
« on: September 13, 2003, 23:42:09 »
I'm picking up my brand new 1971 280 SL next week and saying I'm excited falls way short.  The car is a 65,000 mile original that has been correctly stored for all of its life in a collector's climate controlled storage building where he housed it along with some other fine gems. Anyway, as I'm a newbee, I'm hoping someone can educate me reference gasoline for this beauty.  I understand that the 1971 280 engine was a lead gasoline model and that the lead in the gasoline actually helped lubricate the valves. I also understand that failure to continue using leaded gasoline can cause problems, but as we all know there is only unleaded available at the pumps. Consequently, my questions are:
1.  Will using unleaded gasoline create a problem for the engine?
2.  Is there a lead additive that should be used?
Sorry for the dumb questions, but I did mention I needed an education! :oops:
Thanking you before hand from Los Cabos,Mexico.
pkiefert
Re: Gasoline
« Reply #1 on: September 14, 2003, 00:30:38 »
Welcome to the group jsolis. Previous discussion of this question indicates NO lead or additive is required as the valve seats are quite hard.  As a new user, you should become familiar with the search function of this site, it works quite well.  Many of your questions, and you will have more :) have probably been answered before.  The more you learn about our cars, the better you will appreciate it's unique engineering.
