Not likely any of those things. Grounding is the first thing to check but it could be a bad headlight switch. I know on 190SL's all the power goes through the switch and then to the ignition. I had a car that had a strange miss that I couldn't locate but only at night. The switch came loose when I turned the knob so I reached under the dash to hold it so I could turn off the lights and burned my hand on the housing. It's not supposed to get hot at all. I put a new switch in and it ran like a new car after that.
Try and see if the switch gets hot after driving at night for a while. Of course, you had the charging system checked out, right?
