Author Topic: Miller reproduction Bosch horns  (Read 7530 times)
« on: September 07, 2007, 10:32:33 »
Got an e-mail advertisment from Millers Mercedes-Benz parts that they have reproduction Bosch horns a set for $169.00 part # 54-0050. Although not idenitical I ordered a set since my horns look like they need to be repainted. So I will post pictures of these horns and the orginal when I receive them next week.
Re: Miller reproduction Bosch horns
« Reply #1 on: September 07, 2007, 11:10:33 »
Somebody is reproducing these.  I don't know how accurate they are, but the reason I know is that some guy in California, expresspart from North Hollywood, is always selling on eBay has them listed regularly; it is only a matter of time before someone else sourced them from the same factory.  With a set of tags I'm sure they'll be fine.  Here's a listing:
http://cgi.ebay.com/ebaymotors/BOSCH-STYLE-HORN-MERCEDES-PORSCHE-VW-12V-NEW_W0QQcmdZViewItemQQcategoryZ38655QQihZ001QQitemZ110166508650QQrdZ1QQsspagenameZWDVW
Note also that I went to Miller's site and saw the photos of the horns.  One peculiar item: it looks like they just laid a larger, inappropriate horn tag on the top of the horn with no visible means of attachment.  Our horns have a smaller horn tag that has two mounting screws.  OLDER horns had a larger tag with one hole in the center.  It looks like the Miller's horns LOOK good, but have the wrong tag on them.  And, how is it attached??
Download Attachment: MillerHornSet.jpg
52.47 KB
The horn tag they show is one from Stoddard which is used on much older horns for Porsche cars, probably 1950's era.  It is also a 6V horn tag.  I have a set of these so I know where they came from, who made them!  They do NOT belong on our horns by any stretch of the imagination.  Stoddard does make a proper tag set albeit still with the the 6V rating, for dressing up 356 horn sets.
Mercedes-Benz Club of America
« Last Edit: September 07, 2007, 11:26:29 by mdsalemi »
« Reply #2 on: September 07, 2007, 13:18:03 »
these are temporary replacement horns till I can get my orginal restored. As long as they work I am not worried. By the way is there an article on horn disasemmblie and restoration in our back logs some were. I could sure use it when I take the two orginal horns apart.
Michael you raise some good questions about how these horns are mounted? I guess I will fine out soon enough when they arrive.
Thank You
« Last Edit: September 07, 2007, 13:20:17 by Bob G »
« Reply #3 on: September 07, 2007, 14:52:00 »
It isn't the HORN mounting that's going to be a problem, there's a tab on the back and that mounts conventionally.  It's the TAG I'm concerned about!  It isn't the right tag, stuck on with no visible means of mounting!
