That's definately some strange looking wear. Have you ever replaced the pressure plate? Is the clutch slipping?
If the flywheel is worn more towards the center it will grab on the outer edge and could wear the clutch disc. I have all my flywheels ground - never turn them on a lathe. The flywheel surface has to be perfectly smooth or it won't work right at all. If it's warped even a little bit the clutch will shudder as you release it from a dead stop.
