Author Topic: exterior color chart for 67 250sl  (Read 5244 times)
tony1158
« on: September 13, 2007, 15:53:06 »
Can anyone tell me if there is any way to obtain a color chart for a 67 250sl.  I recently had the car painted and the hard top came back the wrong color.  It had been a rust color and it is now brown.  I need to locate the paint number.  I was also wondering if it can be obtained by the vin number?
Re: exterior color chart for 67 250sl
« Reply #1 on: September 13, 2007, 16:38:09 »
There's a stamped steel plate with a series of numerical codes on the driver-side of the engine compartment.
On the second line is a series of numbers followed by either a "G" or "H." The first series of numbers is the body; the second number is the hardtop. (180G is silver grey metallic, for example.)
You'll find a key for the paint codes in the database section of this website.
(This information will only be helpful if your hardtop and its paint are original to the car, of course.)
ejm
« Reply #2 on: September 14, 2007, 15:02:48 »
408 havana brown                                                      460 dark red brown                                                     461 bronze-brown metallic                                             462 tunis beige metallic                                              463 copper metallic                                                  These are 250sl paint codes in brown. Hope this helps
