Hello All!
I just installed a set of new Euro headlights that I purchased from Adsit. I followed the procedure below (from an earlier post... thank you!). Procedure worked great !!! The lights, and... fog lights light up nicely
:?: :?: My question is... has anyone been able to figure out how to add to this procedure and make the front side marker lights blink with the blinkers
Thank you!!!
How to Connect European Head LightsThe euro light has a 6-prong connector (male), of which 5 of the connectors are used (out of the box). The standard sidelight has 2 male prongs. The following procedure can be used so that you don't cut any wires and can return the set-up back to the original if desired.
You will need the following materials for each side:
1. Bullet electrical connectors, one male and two female.
2. Two 1-foot long lengths of 14 gauge wire.
3. One circle eyelet electrical connector.
One male and one female bullet connector is connected to one wire
One female and one circle eyelet connector is connected to the other wire.
For the 1st wire that has one male and one female end, the male connector is inserted into the 6th hole of the 6 prong euro light harness so that there are now 6 male connectors form the euro light harness. The 6th hole is open and not used when taken out of the box. The female end of the wire is connected to one of the two male connectors of the sidelight (does not matter which).
Now connect the 6 prong female harness to the euro light harness that now has 6 male connectors.
For the 2nd wire that has the female connector and a circle eyelet connector, the female end of this wire is attached to the other male prong of the 2-prong (male) side light wire. The other end of this wire is grounded to the bottom of the light bucket with a sheet metal screw through the eyelet.
There is a way to make the connections so that your sidelight is activated with the blinkers. This procedure is not included….
bpossel (Memphis, TN.)
'71 280SL / '97 E320
