Author Topic: 230 SL Engine Mountings  (Read 6535 times)
230slhouston
  • USA, TX, Houston
« on: September 17, 2007, 12:40:58 »
 :?: Are the left/right engine mountings identical or is there a difference in hight?
Both on my car are compressed so I canno tell the difference.
MBP
Re: 230 SL Engine Mountings
« Reply #1 on: September 17, 2007, 13:36:33 »
Hello. I believe the left & right motor mounts are the same -- the kit comes with the two and the necessary hardware. It is the rear (or transmission) mount that is slightly different.
« Reply #2 on: September 17, 2007, 15:16:03 »
Originally there were right and left side motor mount.
The 8th of the 10 digit MBZ part number when even is for left side parts, and odd when for the right. 0 usually means for both sides
ex
113 123 01 17  (right)
113 123 02 17 (left)
This is a fictitious part number
Al Lieffring
66 230Sl
Jones'n for a new gas tank
« Last Edit: September 17, 2007, 15:24:40 by al_lieffring »
« Reply #3 on: September 17, 2007, 15:34:36 »
What he said... :oops:
I kind of meant they look the same!
« Reply #4 on: September 17, 2007, 23:22:37 »
Rear mount is the same as a 190SL motor mount.
230slhouston
  • USA, TX, Houston
« Reply #5 on: September 21, 2007, 13:18:17 »
Are the engine mounts interchangable?
MBP
