Author Topic: servo unit removal  (Read 4796 times)
gnj588d
servo unit removal
« on: September 20, 2007, 13:51:33 »
Can someone tell me whats involed in removing the servo unit on my 66 230 auto,is it a big job?  Thanks Mike Rutledge
Re: servo unit removal
« Reply #1 on: September 28, 2007, 14:42:22 »
Mike,
The power steering oil pump, the stearing gear box or the brake booster (brake "servo")??
(Magdeburg, Germany)
« Reply #2 on: September 28, 2007, 15:49:39 »
Hi, Mike,
If you're talking about the brake servo, its quite easy.
I used a syringe to empty the resevoir. Then disconnect the brake pipes and remove the master cylinder.
Disconnect the vacuum pipe - at the manifold is easier.
Next, undo the 4 nuts holding the servo to the alli bracket and it should fall out!
The push rod from the brake pedal is not connected with a pin etc.
Any reason for taking it off (other than polishing)? [:p]
« Last Edit: September 28, 2007, 15:51:06 by naj »
