Author Topic: PCV hose issue  (Read 3711 times)
glcg123
  • Canada, MB, Winnipeg
PCV hose issue
« on: October 15, 2007, 13:11:37 »
On my 230SL there is a hose assembly that takes oil fumes from the top of the valve cover, over the exhaust manifold, and down to a short rubber hose. This short hose feeds into an area just ahead of the throttle body. The hose is larger at one end than the other and also has a 90 degree bend in it. I replaced this hose three years ago and it is again cracked. I only drive about 1000 miles per year. Any ideas what might be causing the deterioration? Do they usually only last this long? The P/N is 127-094-04-91.
Could it be new old stock from Mercedes that is deteriorating due to age?
George
1965 230SL - 4 speed
Re: PCV hose issue
« Reply #1 on: October 15, 2007, 13:19:49 »
Hey George. Not quite sure why that would deteriorate so quickly. I just replaced mine. I guess time will tell...
By the way, the hose was the subject of this fairly recent thread:
http://sl113.org/forums/index.php?topic=6922
glcg123
Re: PCV hose issue
« Reply #2 on: October 17, 2007, 08:14:36 »
Thanks for the info. I checked with a mechanic friend of mine. He says it is likely old MB stock. There is a shelf-life to some rubber products. I will use a thin plastic tube on the inside of the new one to protect it.
George
