Author Topic: Power steering pump  (Read 5948 times)
gnj588d
Power steering pump
« on: October 19, 2007, 13:23:03 »
I have just found out where the leak is on my power steering pump,Its from a small blanking plate on the side near the top,its got a pin in front of it to retain it.Has anyone got any ideas for the best way to fix it? Many thanks Mike Rutledge U.K.
Re: Power steering pump
« Reply #1 on: October 19, 2007, 15:58:41 »
I think the pressure valve is behind the plate. It has O-rings if I recal.  You will need to dis-assemble and replace the o-rings. I would replace the front seal while your at it.
gnj588d
« Reply #2 on: October 20, 2007, 08:41:53 »
Thanks Joe,I have ordered new seels.Cheers.
« Reply #3 on: October 21, 2007, 08:02:39 »
I think you need to take the pully off to do anything with the pump.  Use the correct tool for removing it.  A wheel pull will damage the pully.
gnj588d
« Reply #4 on: October 25, 2007, 14:43:22 »
I have taken the pump apart but the pressure plate is held by a pin which looks diffacult to remove,is the pin and plate under pressure,if so it looks hard to get back.Any advice appreciated.  Mike Rutledge.UK
« Reply #5 on: October 25, 2007, 16:58:20 »
yes, there is a spring under pressure behind the plate.
Al Lieffring
66 230Sl
a-cheesin with a new 85 l. tank
