Author Topic: HELP.What a delema !  (Read 4306 times)
colinwoodburn
« on: October 21, 2007, 14:40:22 »
I have just purchased a very presentable 113 280 SL .Ex South African car with little or no chassis decay (RUST) having only a single garage I will have to sell my R107 300 SL much to my better judgment .Does anyone out there have a solution ? building another garage is not an option unless its on top of the existing one. (double decker garages is there a market for these) Any way your thoughts would be most appreciated ,although I expect slightly biased towards the Pagoda . Many thanks Colin @Edinburgh
seattle_Jerry
Re: HELP.What a delema !
« Reply #1 on: October 21, 2007, 15:10:29 »
You can make a taller garage and buy one of those hoists that lift one car out of the way while leaving room to drive the second car in under the first. Here is one link I found:  http://www.alibaba.com/showroom/Car_Hoist.html
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #2 on: October 21, 2007, 19:32:44 »
The lift is an absolutely great solution if you have the overhead room.  It will be an invaluable tool for maintenance.  It will also lead to meeting other car guys who need to get their cars off the ground for one procedure or other.
'68 280SL 4-spd Coupe
colinwoodburn
« Reply #3 on: October 25, 2007, 10:49:34 »
thanks for your help but I am really neading someone to talk me into selling the 107 as the easyest option availlable.Will put the car lift on the shelf as plan "B"
« Reply #4 on: October 26, 2007, 20:28:46 »
Convert a spare bedroom to garage. My neighbor added a room in front of his garage where the driveway was. The back-wall of that new garage has a metal roll-up door. Behind it he keeps his collector's vehicle.
peterm
« Reply #5 on: October 27, 2007, 08:02:39 »
i have a lift and its a wonderful solution.  I do no work on my cars and with the proclivity for some fluid or another dropping down to the car below i would suggest not geting a service lift but rather a solid floor lift.  You do need clearance yet with smaller (read lower cars), youd be surprised how easily you can stack two cars.  You need electric and be aware roll up doors and electric door openers compromise clearance
190SL
« Reply #6 on: October 28, 2007, 10:33:53 »
colin
have a metal cover for the soft top you expressed an interest in.
contact me at csvs@embarqmail.com.
al
