Author Topic: speedometer cable problem  (Read 4657 times)
Cabo Bill
« on: October 25, 2007, 15:11:14 »
Hi- should my new speedo cable(from k&k) have come with the rubber seal on the tranny end ? I can't reuse the old one because they changed the way it fits on the new cable. I also was thinking about changing the rear motor/tranny mount since I have it exposed. Any advice or info will be helpfull. thanks Bill 71 280 SL automatic
Re: speedometer cable problem
« Reply #1 on: October 26, 2007, 02:32:18 »
Here is a photo of a new cable I have.  No rubber seal though
Download Attachment: Speedo Cablea.JPG
56.32 KB
Australia
69 280SL Manual
02 320ML
05 A200
Cabo Bill
« Reply #2 on: October 26, 2007, 10:19:12 »
Garry- thanks for the reply-My cable looks to be the same brand (GEMO),but yours is for a manual tranny, I assume, so I don't know if that would make any difference. The post by r.bartl on 6 Oct 2006 shows the rubber seal that came with his cable. Maybe different brands include it? Bill 71 280 SL automatic
« Reply #3 on: October 26, 2007, 10:44:41 »
My manual tranny speedo cable (original?) has a rubber seal.  It compresses in the housing against an oil seal for the driven gear shaft.  It keeps road dirt, moisture, etc from attacking the inside of the speedo cable.  Here is a pic of the manual trans speedo cable connection.  The picture is upside down from the final installation.
Download Attachment: speedo cable.jpg
50.81 KB
When installed the cable is inserted from underneath the housing at a 45 degree angle.  The driven gear shaft connection is about 1 inch deep inside the housing. The rubber ring on the cable is about 1/4 - 3/8 inch in height and it seals the opening in the area beneath the bolt in the pic.  Without it a gap about 1/8 inch wide by 1/4 inch or so is open and exposed to the elements.  This gap can be easily filled by a short pice of rubber 5/8 dia hose.
