Author Topic: IP Ball Pressure Valve Renewal  (Read 13511 times)
DavidBrough
« on: October 31, 2007, 12:54:31 »
I’ve finally decided to resolve my warm start issue which I am fairly sure is caused by a leaking IP ball pressure valve between the pump and the injection lines. The car always starts but when warm and left for more than about 1 hour it only runs on 5 cylinders for the first 15/20 seconds. I think this is due to one of the pressure valves leaking and wonder if it is permissible to change just one or must all six be changed as a set.
Whist changing all six would negate the need to track down the offender, at £75 each they are not cheap.
Does anyone have any thoughts on this and also the best way to isolate the leaking valve, can I just remove all the pipe connectors and fill the valve housings with fuel and see which one leaks?
Many thanks.
David Brough
1969 280SL Auto with A/C
Re: IP Ball Pressure Valve Renewal
« Reply #1 on: October 31, 2007, 13:22:12 »
After hot starting your engine, quickly while the miss is still present, remove the spark cables one at a time and find the cylinder that doesn't change when disconnected. (pull them loose before starting so they will come off easily)
I had made up a pair of spark cable pliars with a wire that ran to the chassis ground so the spark voltage would ground through the wire instead of through me.
Al Lieffring
66 230Sl
a-cheesin with a new 85 l. tank
« Reply #2 on: October 31, 2007, 13:25:40 »
Also keep in mind the injector may be leaking down as well. either end of the line will cause a drop in pressure which will allow the fuel to boil(Vapor lock) in the line.
DavidBrough
« Reply #3 on: October 31, 2007, 13:57:57 »
Thanks guys,
I have recently replaced all six injectors and was rather hoping that there may be a better way of isolating a leaky ball valve than removing the HT leads, a good last resort but I always seem to get a jolt when I do things like that.
Does anyone have any thoughts on the advisability of just replacing a single pressure value?
David Brough
« Reply #4 on: October 31, 2007, 14:25:08 »
I don't see any reason why you absolutely need to replace all check-valves at the same time.
Another idea: have you inspected the the offending check-valve itself?  Is it scored/worn, or is there just some crud in the valve itself that can be cleaned out?  I suspect a Bosch service shop has the equipment to clean out any crud that may be preventing the valve from closing properly.
Waqas ('Wa-kaas') in Austin, Texas
DavidBrough
« Reply #5 on: October 31, 2007, 15:15:35 »
Thanks Waqas, I will remove all six and give them a good inspection and clean but sometimes it is quite difficult to see slight wear. I do remember reading somewhere on this forum that, when changing injectors, it is recommended they all be done together as the new ones are slightly different from the originals and I didn’t know if this may also be the case with the pressure valves.
David Brough
1969 280Sl Auto with A/C
« Reply #6 on: October 31, 2007, 22:42:37 »
Hello David,
I believe the later ball-check-valves have a plastic sealing washer underneath the check-valve seat. I don't know if these are user-replaceable, but if so, whilst you have the valves out for cleaning perhaps you can replace these washers first and see if there's still a leak.....
I can understand replacing all injectors at once, as these have a direct impact on combustion. But from my understanding, check-valves are there simply to keep the lines charged up whilst the engine is turned off. So, I think replacing just one should be ok.
« Last Edit: October 31, 2007, 22:43:39 by waqas »
DavidBrough
« Reply #7 on: November 01, 2007, 07:50:10 »
Thanks Waqas, that all makes good sense.
David Brough
« Reply #8 on: November 01, 2007, 08:46:30 »
I read your comment about removing high tension leads. I always remove them from the distributor and not the plug and never get shocked.
« Reply #9 on: November 05, 2007, 08:19:27 »
David,
Any chance you can take some pictures of the ball valves?
mbzse
« Reply #10 on: November 05, 2007, 16:18:07 »
Quote
Here's one
/Hans in Sweden
« Last Edit: April 05, 2010, 13:50:59 by mbzse »
/Hans S
« Reply #11 on: November 05, 2007, 20:57:38 »
Notice the groove around the ball check valve in Hans' picture. The groove indicates it is the later improved version.
« Reply #12 on: November 11, 2007, 08:08:09 »
I have the same issue with my car.  How do you remove the check valves?  Is there an alternate method to using the MB or Bosch extractor tool?
Thank you
« Reply #13 on: November 11, 2007, 20:49:31 »
Hell Jeff,
The side of the check valve is threaded. You can find a metric hose fitting to fit it. The Mercedes air suspension cars used the correct fitting find a used one or order a new one for a couple of bucks #112 997 1572. Screw the fittin on and grab the fitting with a vice grip and pull the valve out! I welded a used fitting on the end of a screw driver to make my own special tool.
« Last Edit: November 12, 2007, 17:22:13 by ja17 »
« Reply #14 on: November 12, 2007, 07:37:47 »
Thanks Joe.  I understand the check valve is held in place by the washer/seal.  I've been trying to figure out the thread size and think it must be 12mmx1.0.  The MB fitting will be a big help.
« Reply #15 on: November 12, 2007, 16:46:53 »
Hey Joe,
The air fitting you graciously gave me at Blacklick for this purpose was labelled 112-997-1572.  I'm sure there's more than one air fitting with the same thread so these numbers will probably both work.
Waqas in Austin, Texas
« Last Edit: November 12, 2007, 16:47:12 by waqas »
mbzse
« Reply #16 on: November 12, 2007, 16:52:58 »
../.. figure out the thread size and think it must be 12mmx1.0.
This is correct, M12x1 is the thread on the top part of this pressure valve
/Hans in Sweden
« Last Edit: November 12, 2007, 16:54:16 by mbzse »
/Hans S
« Reply #17 on: November 12, 2007, 17:21:14 »
Hello Waqas,
Thanks, you are correct. I double checked my notes. #112 997 1572. I am not sure where I got the other number (possibly is the same fitting?). I am correcting the part number on the previous post.
« Reply #18 on: November 12, 2007, 18:03:44 »
Thanks Hans and Joe!
