Author Topic: MB Datacard digital image & CODE translation  (Read 4243 times)
k
« on: November 06, 2007, 08:01:23 »
This email:
Classicparts@mbusa.com
returns your
-datacard digital image
-a code translation in 3-6 hrs.
Before I got a fax from MBUSA in NJ.
Engine: 12XXXXXXXXXXXX
Transmission- 59XXXX
291- Paintwork, Dark olive
216- Interior Trim, Cognac Leather
401- Single seats
416- Hardtop mounted
426- Mercedes-Benz power steering and automatic transmission with floor
shift
461- Instrument with mileage reading and English lettering
491- U.S. Version
503- Outside rear view mirror on the right
524- Paintcoat preservation
533- Interference suppression without radio set
598- Heat-insulating glass, all-around
600- Trim strips on hardtop
641- White-wall tires
669- 10 liters of fuel and mode of packing VE IV
730- Folding top fabric, Beige
Front right/left axle- 427
Rear axle- 004XXX
Steering box- 14XX
Kemal
Re: MB Datacard digital image & CODE translation
« Reply #1 on: November 06, 2007, 09:04:27 »
How ?
Kemal
280 SL Manual 69
Kemal
280SL
Manual LHD69
k
« Reply #2 on: November 06, 2007, 09:27:54 »
Send them your VIN ID # to that email above
Kemal
« Reply #3 on: November 06, 2007, 09:37:08 »
Thank you, will do.
Kemal
280 SL Manual 69
Kemal
280SL
Manual LHD69
« Reply #4 on: November 06, 2007, 10:31:00 »
Alternatively, find it all yourself in our manual...
http://www.sl113.org/wiki/pmwiki.php?n=DataCard.Start
RBYCC
« Reply #5 on: November 06, 2007, 12:29:27 »
K
Emailed them this morning, received the digital image of the data card along with the breakdown in four hours !!!!!
Thanks !!!
ED A.
1988 300CE TWIN TURBO
1990 C43 AMG
2003 G55 AMG
k
« Reply #6 on: November 06, 2007, 13:04:48 »
Actually, I got mine in 2 hours 59 minutes. Let see if that is beat.
I did this 4 years ago via the fax system, and you had to translate yourself.  They must have set up a relational database.
The coll part is engine, trans, etc. #s.
It says mine has no radio; and it has a becker, with inner amp under dash.  Must have been dealer install.
RBYCC
« Reply #7 on: November 06, 2007, 13:32:22 »
TO BE EXACT.... ;)
Email sent 10:23:16
Email received 1:02:35
Response time 2:39:19 :D
My car listed with "040" upper paint work as "Black" with lower paint work the color it is now Red ( 576).
Do I understand this as my hard top was black from the factory ?
ED A.
1990 C43 AMG
2003 G55 AMG
« Last Edit: November 06, 2007, 13:36:56 by RBYCC »
« Reply #8 on: November 06, 2007, 14:58:55 »
Originally posted by RBYCC
Quote
ED A.
1990 C43 AMG
2003 G55 AMG
Yes, Ed. It means you had a black hardtop and matching wheel covers originally. (IMHO, a handsome color combo.)
You may want to check the aufbau # on your hardtop just to see if it's original. There should be a number on the passenger side corner. Remove the hardtop, look closely and you'll find it. This same # should be indicated on the tonneau cover, hood and on the body-colored cover that rests underneath the transmission.
RBYCC
« Reply #9 on: November 06, 2007, 16:33:48 »
Your response is much appreciated.
Hard top currently painted red ( 576 )
Not sure if it is the original top, but I will check based on your input.
I think I will return it to the original black along with the hubcaps.
Posted last week that I picked up 5 Bundt alloys and tires for the incredible price of $41.00.
Having the tires taken off and trashed and will get the alloys powder coated.
For the price I couldn't resist...!!!
ED A.
1990 C43 AMG
2003 G55 AMG
