Author Topic: Relay Bushings  (Read 5033 times)
Roman Kishi
  • USA, VA, Fairfax
Relay Bushings
« on: November 14, 2007, 20:39:59 »
Hallo all
Are these rubber/brass bushing avilable? does it have a part# ?
Local MB parts dept said I have to buy the whole relay......not
Thanks for the help
Download Attachment: Relay.jpg
21.34 KB
Roman
Northern Virginia
Roman
Northern Virginia
Tom Colitt
Re: Relay Bushings
« Reply #1 on: November 15, 2007, 01:09:24 »
Yes. Unfortunately they are only available with a new relay.
Tom Colitt
mbzse
Re: Relay Bushings
« Reply #2 on: November 15, 2007, 02:23:31 »
Interesting subject. I have hunted high&low for a rubber grommet the correct size&shape (square profile). Asked lots of German suppliers, and German M-B clubs (this part is fitted to all M-B of the period). No success.
Best bet until now is to glue one together, make the part from two rubber discs, with a smaller dia piece in between. Save the brass center from the original part, insert into the "sandwich".
I do not really understand why Bosch won't sell the separate grommet. As Tom writes, they do come attached if one buys a new relay (expensive...).
A Bosch part No would be great
/Hans in Sweden
« Last Edit: November 15, 2007, 23:50:10 by mbzse »
/Hans S
Paddy_Crow
Re: Relay Bushings
« Reply #3 on: November 15, 2007, 07:18:32 »
When I need to make my own grommets, I start with rubber hose and faucet washers.
Markus
Re: Relay Bushings
« Reply #4 on: November 15, 2007, 09:13:35 »
You could always check a Mercedes salvage yard, thats where I got some of mine. Typical problem, relay is fine but rubber grommets dried out and cracked. They will also most likely sell you the whole relay for 5-10 bucks. These relays usually don't go bad, and can be easily rehabed (mostly)by bending back the crimped points, and gently passing some 1500 wet/dry paper between the relay contacts. Slide  through the contacts a thick piece paper soaked in alcohol/laquer thinner (let dry)test using battery charger or battery and you have a spare relay to boot along with your other spares in the car. (fuses,points,rotor,cap,condeser) 8)
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: Relay Bushings
« Reply #5 on: November 16, 2007, 07:09:29 »
I agree with Markus, I found thes.  You can find these relays in salvage yards, bought the entire used relay, just for bushings.  You will find these in several MB models 1965-1980.
Robert Hyatt
Williamsburg, VA.
1970 280SL, Red on Silver,4-speed, Euro spec; 1999 C230 Kompresser Sport, Black on Black; 1990 Miata, Black on Red, 5 Speed
Robert Hyatt
Williamsburg, VA.
