Author Topic: Heater Question/Survey  (Read 2684 times)
bluedipper
« on: November 15, 2007, 12:25:31 »
Now that the weather is cooling here in California, (Brrrr, can you believe the temprature drops into the 40s and 50s here at night?) I've noticed that my heater seems to be less than efficient.  I know, check the valve, hoses, core, etc. but I'm just wondering if this is normal for these cars.  Is it a common problem?
Chuck Gale
68  250SL
Hardtop now on
Re: Heater Question/Survey
« Reply #1 on: November 15, 2007, 12:59:14 »
Hey Chuck. This came up in a recent thread -- and I think the consensus was that if all is working properly, the heat output is actually pretty good. I know mine gets the job done and I am in a slightly cooler area than you (Nevada County) But not much.
Now, the catch is the part about "working properly." I know I had to have my heater core and valve etc overhauled -- about 10 years ago. I think many of us had or will have to do this at some point. (maybe others can confirm this part?) Good luck.
lurtch
  • USA, CA, Santa Rosa
  • " ICON 66 "
« Reply #2 on: November 15, 2007, 23:01:12 »
Hi Chuck - - - Perhaps the first thing you should do is pick the top off the thermostat housing and see if there is one in there!  My  engine never gets hotter than 180 deg because I removed it to troubleshoot an overheating problem and as yet have not installed a new one.
Larry in Menlo Park
Larry Hemstreet  in  N. Cal.
1982  300TD-T (parted out)
1986  560SEC (totaled)
1991  300TE (gifted)
1998  E320 (sold)
2004  E320 wagon (gifted)
2008  CLK550 Cabriolet
