Hi Andy,
You can remove the A/C vent housing and blower, located inside the car, without removing the other components from the engine bay. But to complete the entire A/C removal from the engine bay, you have to remove the compressor, dryer, evaporator and condenser.
This then also requires replacing the water pump with the longer housing version. You will also need to remove the very large bracket that holds the compressor and replace it with a smaller bracket which holds the alternator in a lower position. You will also need a different pulley with one less grove since the belt for the compresser will no longer be needed.
In addition, you will need some additional rubber grommets to plug the holes in your firewall where the dryer hoses used to connect.
It is a lot of work! But if you like to work on your own engine, it is worth it! I found it so much easier without the A/C system installed.
Good Luck and keep use posted,
bpossel (Memphis, TN.)
'71 280SL / '97 E320
