Author Topic: top hardware and door internal rubber needed  (Read 4248 times)
pauldridge
« on: November 19, 2007, 20:39:02 »
I need the following replacement parts, wondering if anyone can offer a source?  (I've looked at miller's Bud Benz, etc, no luck)
1) soft top frame pivot bolts/screws... these are the pieces that hold the frame together.  One of mine has stripped threads
2) Little rubber bumper thingy's INSIDE the door which keep the door latch and lock rods from rattling (the rods go THROUGH these rubber stand-off bumpers.
Part numbers would be great if anyone has a source
230SL, 59 Jag MK IX, 65 Stingray Roadster, 89 Carrera Cabriolet
Re: top hardware and door internal rubber needed
« Reply #1 on: November 19, 2007, 21:09:14 »
Hey Phil. I had the same trouble finding the Inner rubber deelies. Ray at Bud's Benz talked me into buying the 107 version. They are not even close! so I ended up using the old ones with some tape to keep them in place... (so if ya find em, grab me a couple!)
« Reply #2 on: November 20, 2007, 04:32:44 »
Have a look here:
http://index.php?topic=7281
A 121 987 0237 Available from MB
« Last Edit: November 20, 2007, 04:37:26 by naj »
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #3 on: November 20, 2007, 07:51:58 »
Paulridge,
Check with your MB dealership.  Part #s are (there are several screws, and I am not sure which you are talking about).
113 984 13 31 Screw, retaining rail to main bow (need 2)
113 984 23 31 Screw (need 2)
000933 006 103 Screw (need 4)
000933 008 115 Screw, folding frame assembly to bracket (need 4)
Good luck
Robert Hyatt
Williamsburg, VA.
1970 280SL, Red on Silver,4-speed, Euro spec; 1999 C230 Kompresser Sport, Black on Black; 1990 Miata, Black on Red, 5 Speed
Robert Hyatt
Williamsburg, VA.
