Author Topic: antifreeze question  (Read 2237 times)
gnj588d
antifreeze question
« on: November 21, 2007, 09:44:00 »
Can I mix two different brands,I need to top up but can not remember the brand I used.  Many Thanks, Mike Rutledge
jameshoward
Re: antifreeze question
« Reply #1 on: November 21, 2007, 14:40:56 »
You shouldn't.
Read the post a page or so down about coolant and how not to drain it.
If you intend to drain and refill - which you should if you haven't done this for a while - don't use the drain plug on the radiator unless you really know you won't shear it off; use the lower pipe instead. Ask me why.
JH
James Howard
1966 LHD 230SL
