Become a Full Member and get the official Linkage Tour and the official Starting Aid. This information alone will pay for your membership
quote:Originally posted by georgemJoe and Naj,Thank you both for your help.In the end, I think I will try and round up an advance dist. - drilling a hole for the vacuum off take in the bottom of the manifold isn`t a major job - but it does drift the car away from originality.Now, does anybody know of a serviceable advance distributor............ ebay here I come.Thanks againGeorge McDonald230SL Brisbane
quote:Originally posted by Benz Dr. ...I think total advance on that unit [046] is about 40 degrees @ 3,000 RPM. It takes a distributor testing machine and a lot of fiddling to get that particular unit to work right...Dan Caron's SL Barnbenzbarn@ebtech.net slbarn.mbz.org 1 877 661 6061
quote:Originally posted by J. Huberquote:Originally posted by Benz Dr. ...I think total advance on that unit [046] is about 40 degrees @ 3,000 RPM. It takes a distributor testing machine and a lot of fiddling to get that particular unit to work right...Dan Caron's SL Barnbenzbarn@ebtech.net slbarn.mbz.org 1 877 661 6061Hey Dan, can you elaborate on the 40 at 3K thing. I have mine at 30 -- should I adjust out.James63 230SL
