Author Topic: Droopy sunvisors  (Read 4119 times)
cpmayor
Droopy sunvisors
« on: December 05, 2007, 14:13:39 »
Hi. Is there a quick fix for droopy sunvisors as an alternative to getting new ones? Looks like the hardware inside the visors have worn out so just wanted to check if anyone has any tips before going in and taking a look. Also, is there anywhere to get replacement sunvisor hardware only, without buying the whole visors? Thanks much.
1968 MB 280SL (W113)
1987 Porsche 930
1995 BMW M3
2007 MB ML350
ejm
Re: Droopy sunvisors
« Reply #1 on: December 05, 2007, 17:14:45 »
tightening the screw a bit on the visor normally sorts it out. careful not to overtighten
« Reply #2 on: December 05, 2007, 21:44:11 »
The least expensive way I found is to purchase a set of reproduction visors from Kay in the UK.  The quality is spot on.  Take a look in the classified section.
cpmayor
« Reply #3 on: December 08, 2007, 13:42:19 »
Thanks. Tightening the screw worked for my left sunvisor, but my right has a bit of corrosion on some of the hardware and won't get tight enough to stay up. So I'll probably have to look at ordering some of those reproductions sometime.
1987 Porsche 930
1995 BMW M3
2007 MB ML350
