Become a
Full Member
Emergency Contact List
Auto Transmission oil change
Topic: Auto Transmission oil change (Read 4869 times)
gnj588d
December 10, 2007, 08:18:15 »
Has anyone any tips on changing the fluid and filter on my 230. Thanks Mike Rutledge
merrill
Full Member
Platinum
USA, TX, Austin
Re: Auto Transmission oil change
December 10, 2007, 11:44:45 »
do not over torque the valve gasket bolts, I think they are 5 ft lbs...
also, if you can using low pressure, blow out the tranny cooler lines
(15lbs or less)
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #2 on:
December 10, 2007, 17:57:55 »
The job isn't done right or at all without draning the converter. There's a small dran plug and you will need to turn the engine over slowly by hand until it lines up for removal.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Full Member
Platinum
USA, OH, Blacklick
Reply #3 on:
December 10, 2007, 22:01:43 »
You may want to get the kit with the new cork gasket, filter and metal ring seals. You will need to have a 5mm allen to unfasten the drain on the torque converter as Dan metioned.
Last Edit: December 10, 2007, 22:02:18 by ja17
gnj588d
Reply #4 on:
December 11, 2007, 06:28:19 »
Thanks for the info Ihave orderd the kit,just one more question how, often should this be done. Cheers Mike Rutledge
Full Member
Platinum
USA, OH, Blacklick
Reply #5 on:
December 12, 2007, 17:32:59 »
Hello Mike,
The automatic transmission oil and filter change interval is 30,000 miles.
