Become a
Full Member
Emergency Contact List
Engine Support — 1100-Lb. Capacity
Topic: Engine Support — 1100-Lb. Capacity (Read 3544 times)
merrill
Full Member
Platinum
USA, TX, Austin
December 23, 2007, 19:17:58 »
FYI,
in case any one needs to remove the subframe with out removing the motor.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200309403_200309403
1100# capacity manual thread rod. This engine support has double groove chains and is used from wheel well to wheel well to help support your engine while working on the transmission/engine! Easy to use and a real money and time saver!
looks like this would work
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Last Edit: December 24, 2007, 04:20:55 by 280SL71
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
psmith
Re: Engine Support — 1100-Lb. Capacity
December 24, 2007, 20:43:33 »
Thanks Matt! I am thinking about doing the subframe this winter and that was one of the things I worried about. I wasn't sure how I was going to support the engine.
Pete S.
