Author Topic: anyone know the part # for the aluminium  (Read 4786 times)
erickmarciano
  • Canada, Quebec, montreal
« on: September 27, 2003, 21:57:39 »
1- the aluminum spacer inside the tachometer drive assembly and how hard to install?
thanks
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: anyone know the part # for the aluminium
« Reply #1 on: September 28, 2003, 06:43:53 »
Is this the one on the engine block??
'Kloines Scheisserle'
erickmarciano
« Reply #2 on: September 28, 2003, 08:26:36 »
yes
is it hard to change?
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
« Reply #3 on: September 28, 2003, 09:02:31 »
Hello Erick,
Search up "distributor chain drive" on this site for the information and photos you need.
 http://sl113.org/forums/index.php?topic=443
« Reply #4 on: September 29, 2003, 03:33:11 »
Erick,
There is a rubber 'o' ring under the alli washer and also a seal (not unlike a valve stem seal in shape) in the housing that you undo to change the washer.
I trust you have read the topic Joe reffered you to. While you are there, its worth checking the 'lift' in the drive gear and shimming it if necessary.
part #s:
126 990 0140    alli washer
621 997 0040    o ring
007 997 7346    seal
« Last Edit: September 29, 2003, 12:56:31 by naj »
isofast
« Reply #5 on: October 03, 2003, 19:39:43 »
Hey Eric it is Ernie in Chicago with the 250SL parts car...I have to put in a new tach cable on my 280 is it pretty easy? Call me I am taking your glass out of the car.
First Place AACA Show Winner 350SL August 2003
I love low mile car's.
1969 280 4spd
