Author Topic: A/C fitting crimper  (Read 4207 times)
pauldridge
A/C fitting crimper
« on: January 01, 2008, 15:24:29 »
After paying $140 to have the two short oil cooler hoses made up with MY fittings at a local hose shop, I decided to spring for my own hydraulic/A/C hose crimper.  It's a pretty heavy-duty, yet simple device.  I got it primarily because I am going to completely re-plumb all my A/C hoses, and wanted to be able to control the exact fitment myself.  I am going to install hard metal through-fittings through the firewall rather than just run hose through rubber grommets, for a neater, more secure installation.
Since this tool will most likely only see 2-3 uses in my lifetime, I'll be happy to crimp any member's hose at no charge (other than actual material cost), if mailing costs make sense.
Once my own project is complete, I'll be happy to lend the tool out, but don't count on that for 2-3 months min.
Phil
Phil Auldridge
230SL soon to be 172 Metallic Grey/blue interior. Auto/AC
Re: A/C fitting crimper
« Reply #1 on: January 02, 2008, 11:09:21 »
Phil
Phil Auldridge
Paul,
Let me get this straight.  YOU supplied the fittings (almost always the most expensive part of hose assembly) AND they charged you $140 to crimp these onto hose?  I think YOU may have been HOSED!  Is there something magical about this hose?
Exactly what kind of hose did they use?  Size?  I'm going to check my friends at Plymouth Rubber and Transmission in Michigan.  I have hoses made all the time (usually high pressure hose in long lengths)and crimping takes moments and costs next to nothing.  If you had some specialty hose or size, it might be time to find a new supplier!!
Miller's has most of the oil cooler lines for between $30-$50 each.  don't know which ones you needed, but they are complete assemblies.
Mercedes-Benz Club of America
George Des
« Reply #2 on: January 02, 2008, 12:41:27 »
Having these new high pressure--R134A compliant--fittings crimped on by a garage is not cheap. I don't recall paying as much, but it was enough to convince me to go out and buy my own crimper--one that could be used to crimp the fittings while the hoses were being fitted in the car because it is very difficult to get a good measurement, take it to someone with the crimper and come back only to find out it was either too long or too short. Trust me, I went through this several times and the measurements are not easy when you are working these A/C hoses under the hood and through the dash--for some reason or other the old adage of "measure twice, cut once" just doesn't seem to apply here and having a crimper in hand made all the difference even though the crimper isn't cheap either.
George Des
pauldridge
« Reply #3 on: January 02, 2008, 14:21:11 »
Phil
Phil Auldridge
Paul,
Yeah, I know... I had seen the Miller's hoses, but my setup is a bit of a bastard since I've got a 280 engine in my 230SL, wasn't sure if the stock hoses would fit or not.  There WERE some extenuating circumstances, they had to braze one part of a fitting onto the old, but still excessive, and, as you suggested, the length wasn't exactly right... I'll have no one to blame but myself for future bad measurements!
Phil Auldridge
« Reply #4 on: January 03, 2008, 17:20:59 »
George Des
George,
When custom hose manufacture by the cut and fit, cut and fit, cut and fit, fit and crimp method is what you need, then a portable or hand hose end crimper is the only thing that will do, I suppose...but I wouldn't trust hand-crimped hose for sure.
But, R134A systems are not high pressure. I don't know what the specific ratings are per compressor, but the hose ratings are working in the 600 psi range, and burst in the 2,000 psi range. This is generally called medium pressure; hydraulic hose such as SAE R2-R16 have working pressures in the thousands, and burst pressures sometimes exceeding 20,000 psi. That's high pressure.
The crimping for hydraulic assemblies (which I have done regularly as I have about a dozen 3/4" hoses, double ended, that need replacement annually but not all at the same time)is done on a hydraulic press, not a hand press, and it is a one step operation that is independent of the hose style or the pressure rating. My guy here in Michigan charges a per foot price for the hose; a per fitting price for each end. Because the hose I buy is a good size at 3/4", and has a high pressure rating, it is about $6 per foot. The fittings are about $9 each. They don't even charge me for the crimping.
I've seen other places on the internet for example, that charge $24 for a custom R134a refrigerant hose with choice of 2 sizes, and several fittings as well; price goes up if you go longer.
But it sounds like someone might be giving you a line. If you go to a hose place (not a garage!) they'll give you reasonable prices for just crimping.
As the saying used to go, let your fingers do the walking, (now on the internet) and trust your judgement.
BTW I wouldn't want any a/c or high pressure hose crimped in a hand press. The a/c systems lose refrigerant too easy and are expensive to service, and leaky high pressure hoses are a pain. I've seen enough bad work out there, and I'm sure you have too. Seek out a good supplier! They are out there
