Author Topic: wiper switch problem  (Read 5484 times)
« on: January 13, 2008, 04:29:55 »
A friend has a 280sl with a wiper switch that could need replacing because the wiper push function of the switch is not 'normal'
My friend wrote an email explaining his problem
quote
My issue is that everything work but end out cap is “ bending” i.e. something inside that secures it to inner section is not right, when is normal position an done pushes outwards to engage washers. Then one pushes in to engage wipers, it “rubs” on inner part and is not the normal easy push and click action
unquote
Is this fixable?
Is the wiper switch on a Lhd car on the left or right of the steering column?
Is it possible to use a Lhd car wiper switch in a RHD car?
If yes would wiring changes need to be made?
all information welcome, thanks
Re: wiper switch problem
« Reply #1 on: January 13, 2008, 12:24:01 »
Left.
Pagoda Technical Manual
1966 230SL
2006 C230 Sport Sedan
« Reply #2 on: January 14, 2008, 05:16:58 »
Thanks.
I kinda think the wiper switch could be turned over and plugged in maybe need some wires swapped.
I haven't seen a switch close up but I reckon it would have symmetrical mountings.
« Reply #3 on: January 16, 2008, 05:59:24 »
Anybody else have any knowledge to offer?
Naj, JoeA?
« Reply #4 on: January 16, 2008, 08:50:26 »
Naj, JoeA?
Column switch A002 545 2924 lhd
and A002 545 5424 rhd
« Last Edit: January 16, 2008, 08:59:20 by naj »
« Reply #5 on: January 17, 2008, 05:50:59 »
Naj,
Thanks for the numbers.
regards
