Author Topic: Sealants & Fitting Preparations  (Read 3099 times)
awolff280sl
  • USA, FL, Sarasota
« on: January 15, 2008, 06:43:43 »
Do any of these fittings require any special compound or prep to ensure a leakproof seal:
1) High pressure steering hose flare fitting?
2) Oil cooler hose?
Also, what is the preparation for the front crankcase seal prior to insertion?
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
awolff280sl
  • USA, FL, Sarasota
Re: Sealants & Fitting Preparations
« Reply #1 on: January 15, 2008, 22:24:17 »
Do the front pan bolts need to be loosened to insert the seal? If so, do you just cross your fingers that you don't create a leak?
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
