Author Topic: RPM drop when using electricity  (Read 6054 times)
bcjm
« on: October 03, 2003, 08:30:57 »
This problem is with my 88 Mercedes 300SEL but it applies to W113 also.  Each time I use something that requires high electricity the RPM drops for a second or two.  Most of the time it recovers but once in a while the car dies completely, especially at idle. Is there any possibility other than a bad alternator?  I am just very surprised that a bad alternator could cause this to happen.  If it is the alternator, should I try replacing the regulator first or should I go ahead get a new unit?
Re: RPM drop when using electricity
« Reply #1 on: October 04, 2003, 04:08:28 »
Could your batttery be your problem and not your alternator?
How old is your battery?
Bob (Brisbane,Australia)
early 250 SL, RHD
bcjm
« Reply #2 on: October 04, 2003, 09:22:35 »
Battery is the first thing I replaced.  Did not fix the problem.
« Reply #3 on: October 04, 2003, 18:56:20 »
Hello bc,
I would definately try the regulator first. The regulator and brush unit unscrew off the back of the alternator.
dwilli3038
« Reply #4 on: October 05, 2003, 05:40:24 »
Hello BC,
Is it possible that there is no problem with the electrical system but rather something wrong with the "tune" of the car. When you use electricity, the alternator needs to take on some addtional load,  causeing the RPMs to just drop slightly , no different from turning on AC. This does not cause problems normaly, but if you have other problems it can magnify them.
Daryl
'64 230 SL
Serial # 508
bcjm
« Reply #5 on: October 06, 2003, 13:30:39 »
I took the regulator off the alternator yesterday.  The brush still have 25%-30% left. Can't really see anything wrong with the brush so I pressed the brush for a few times (a bit sticking) to make sure the spring is OK. The first thing I noticed after re-installing the regulator is that the noise in the stereo is gone.  It has been there for a while, does not matter it was in AM or FM.  The RPM stays complete stable when using any electrical device.   Hopefully it is not my imagination.
