One oddness about the M130 motor, is that the 1968 ones have different cam dimensions. If you mix up various towers, cams, rockers and thrust pieces from assorted motors, get them in nice uniform sets.
If your cam lobe is a mm or so shorter, a different rocker and thrust peice can compensate. It was lotsa fun discovering this as I hand turned the motor after putting it back together.
Also, don't sleeve the block. Get another one.
-CTH
