Author Topic: spark plugs 250 sl  (Read 8051 times)
rmmchl
  • USA, WV, Charleston
spark plugs 250 sl
« on: February 03, 2008, 13:10:35 »
what are the correct plugs and gap
« Last Edit: February 03, 2008, 13:44:03 by 280SL71 »
michael romeo
1967  250sl
signal red
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: spark plugs 250 sl
« Reply #1 on: February 03, 2008, 15:23:26 »
Bosch W7DC .9 mm (.035 in) is the short answer.
Do a search for Spark Plugs.  There is about everything you could want to know about the plugs for these cars.
'68 280SL 4-spd Coupe
« Reply #2 on: February 03, 2008, 15:41:40 »
I won't use W7DC - they're too cold on all but the best engines. This plug was intended for when the engine was new and doesn't work well on rich running or lower compression engines. I use W9DC0 for everything these days.
« Reply #3 on: February 03, 2008, 16:48:38 »
Hi Dan,
what is the difference between a W9DCo and a W9DC?
« Reply #4 on: February 03, 2008, 17:07:34 »
Perhaps this Spark Plug nomenclature chart will be helpful.
Richard M
Download Attachment: sparkplug.jpg
45.7 KB
« Reply #5 on: February 03, 2008, 20:55:55 »
What plug is the equivlant in the NKG line for a 280SL with 90,000 miles?
« Reply #6 on: February 03, 2008, 23:08:02 »
Thanks Richard.
It is quite helpful - now I know that the "zero" stands for "special shell or electrode" - but perhaps what I should have asked the good doctor was why the difference between a W9DC ad a W9DC0 is significant and/or important.
