Dan,
The check valve is not blocked (removed and and checked it out), I removed it and there was decent flow volume, same as the inlet. I measured the flow, it is almost 3 liters in 30 seconds. Could it be pressure? However, the return line line is a lot less, is it possible the pressure is to low to activate the check valve?
Does anyone know were I can buy a cheap pressure gauge to measure the pump pressure?
BTW, I did do a pump repair with a kit from George Des.
Maistran
Maistran (MB)
230sl
