Author Topic: turn signal and wiperswitch  (Read 4349 times)
1979speedster
« on: February 25, 2008, 23:05:03 »
Is there an easy overhaul ,it will not lock in the position I am turning. And I read European is different than the U.S. model. I have a 67 250 sl european model.
art dapran
Re: turn signal and wiperswitch
« Reply #1 on: February 26, 2008, 04:58:50 »
I believe the column lever switch is the same for USA and Euro cars. Euro cars have the "Passing Flasher" activated while USA cars have this function disconnected.
Here's the Tech Manual section about repairing the lever.
http://www.sl113.org/wiki/pmwiki.php?n=Electrical.Lightswitch#Column
Richard M, NYC 1969 Euro
1979speedster
« Reply #2 on: February 26, 2008, 21:34:59 »
I worked on it today just cleaned it slightly lubricated it  and put it back together and it seems to work O.K..It worked fine before I took the car apart to repaint it. Now are there any rubber boots left to cover the turn signal lever.  And thanks for the info
art dapran
