Author Topic: Lower Oil Hose "Donut"  (Read 5363 times)
awolff280sl
  • USA, FL, Sarasota
« on: February 26, 2008, 20:38:41 »
My lower oil hose has a solid rubber "donut" on it, whereas the non-MB replacement does not. What is the purpose of this? Do I need it?
Andy
Sarasota, FL
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: Lower Oil Hose "Donut"
« Reply #1 on: February 26, 2008, 22:09:28 »
I believe it is to prevent the line from chafing against the edge of the power steering pump bracket.
'68 280SL 4-spd Coupe
« Reply #2 on: February 27, 2008, 18:47:50 »
Pardon my ignorance.  What is an "oil hose"?  I put oil in the top of the engine and drain it out the bottom.  No hose required.
Pagoda Technical Manual
1966 230SL
2006 C230 Sport Sedan
« Reply #3 on: February 27, 2008, 19:07:42 »
Right on Rodd- Tranny oil, oil cooler hose, after market, power steering, vegetable oil conversion, ????.  Anything can happen in PPP-Possible Pagoda Purgatory.
« Reply #4 on: February 28, 2008, 05:38:54 »
Hello Rodd,
Your 230SL does not have an oil cooler or rubber oil hoses.  The 280SLs ll had an external oil cooler with two oil hoses running from the engine to the oil cooler which is next to the radiator.
« Reply #5 on: February 28, 2008, 10:34:00 »
Righty oh, Joe.  How about the 250's oil cooler?   MB just kept trying to cool em down.   non sequitor--  Was it Buddy Baker that won the Daytona '450' 11 times?  His words.  Then he won the 500 on the 17th(?) try.
