I'm not so sure !
The part that is bolted to the windsheild frame is chromes, but the swinging part appears to be pressed in and then bent afterwards. This means if I chrome it first it will be hard to bend without heating it and if heated the chrome plating will be damaged. Also where it is pressed into the bracket the end of the rod is stamped into a slight dome to stop it falling back out !
I dont think it would be too easy to replicate !
Problem is it broke right on the bend and someone tried to weld it and it didn't last so there is less room to weld it again !
'03 CLK Kompressor
