Author Topic: decorative door strips  (Read 7382 times)
paulr
« on: March 03, 2008, 12:33:37 »
does anyone know how to attach the lower aluminium strip to the door. I just cannot get the clips into the door with the strip attached yet cant see that the strip is slid on.
paulr
lovely 1970 280 SL
Re: decorative door strips
« Reply #1 on: March 03, 2008, 13:26:50 »
The way I've done it is to slip the lower portion into the clips then gently push the upper part into place. No sliding.
paulr
« Reply #2 on: March 03, 2008, 14:21:44 »
so the clips are in the door then and each is done one at a time?
paulr
lovely 1970 280 SL
« Reply #3 on: March 03, 2008, 14:35:42 »
paulr
lovely 1970 280 SL
Yes, that's how I've done it.
paulr
« Reply #4 on: March 03, 2008, 15:09:09 »
Douglas. I thought that the 'butterfly wings' went inside the groove leaving nothing between the strip and the car body. Now that I have examined them I see that they are slightly wedge shaped and I have slipped them into the strip with the "wings" on the outside to form a barrier between the two metals. Easy. It's on and looks great.
That is a great example why I don't get involved. I just don't see these things.
Thanks a lot. I knew you'd know.
paulr
lovely 1970 280 SL
« Reply #5 on: March 04, 2008, 03:19:09 »
paulr
lovely 1970 280 SL
Too late?
http://www.sl113.org/forums/uploaded/naj/2006812105749_Mldg04.JPG
paulr
« Reply #6 on: March 04, 2008, 11:14:05 »
thanks Naj
I think I'm sorted. However, I did it the other way around. Clips into the chrome then pushed the whole lot into the door. Seems to be tight.
paulr
lovely 1970 280 SL
Too late?
paulr
lovely 1970 280 SL
« Last Edit: March 04, 2008, 11:15:21 by paulr »
« Reply #7 on: March 04, 2008, 12:59:51 »
Hey Paul. You are lucky that technique worked for you. Only because, I did mine that way -- most went on fine -- but one ended up with thumb impressions because I was pushing so hard...
Louiehenry
« Reply #8 on: December 02, 2013, 15:13:07 »
Does anyone know where to buy new clips?
Larry & Norma
« Reply #9 on: December 02, 2013, 16:33:14 »
sls
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
Flyair
« Reply #10 on: December 02, 2013, 22:34:59 »
often on eBay too
Stan
2011 SL550 AMG
2011 GL
2015 GLA
KevinC
« Reply #11 on: December 03, 2013, 02:59:38 »
MB still stocks them. My local dealer got some for me in about three days.
