Originally posted by wgl0
After 40 years the original coil went away and had to be replaced. The MB dealer said that the original coil is no longer made and substituted another one. Can someone verify the part number as a correct coil for the motor and distributer. The cap contacts have gotten burnt and I am not sure why.
New part #000-158-28-03
Motor #130983-12-001870
Distributor #0231 116 051 black iron
Bill Lindquist
68 280SL Signal Red
Hello, Bill,
Part #000-158-28-03 is the later coil for the transistorised ignition system and NOT suitable for your cast iron '051' distributor.
My choice would be the Bosch 'RED' coil MB part # 000 158 49 03 (Bosch 0 221 119 030).
To use this, you would also have to change the ballast resistor to 1.8 ohm (with a red band) MB part # 000 158 1745 (Bosch 0 227 901 014 or Beru WZ 18-2).
P.S: The original Bosch Black Coil is no longer listed but there is a Beru equivalent: ZS 115 to use with the current 0.9 ohm resistor.
Also, treat the car to a new cap and rotor and check HT leads and ends for correct resistance. [:p]
Hope this helps
