Author Topic: My Data Card  (Read 5705 times)
benzportland
My Data Card
« on: March 14, 2008, 20:34:58 »
Hi all - I emailed the classic center in LA area earlier this week and they responded today via email with the card and a translation, all I needed to do was give them the VIN.  Here's the translation:
HELLO,
TRANSLATED DATACARD PROVIDED BELOW. GOOD WEEKEND!!
(Embedded image moved to file: pic18467.jpg)
Engine: 127981-10-007773
Transmission: 008075
568- Lower Paintwork, Signal Red
717- Upper Paintwork, Papyrus White
201- Interior Trim, Black Leather
401- Single Seats
416- Hardtop mounted
422- Mercedes-Benz power steering and automatic transmission with floor
shift
565- Cross and rear seats used on SL Models
600- Trim strips on hardtop
720- Folding top fabric, Black
Front left axle- 099272
Front right axle- 099273
Rear axle- 010026
Steering box- 54716
Wheel: 6J.14H
Tire: 185.14Phon.
Shipment: March 29, 1965
I am going to try an attach the image of the data card.  What I know about the car is that it was Euro market, and apparently originally had manual transmission. It is now all signal red but apparently the top used to be white.  From the engine number it appears it now has an engine from a 250c or ce (129-980-10-014426).
I am wondering if anyone could give me any more info from this card?  For example, whether it had a radio or was "radio delete," etc?  I am not familiar with these cards at all so any help would be appreciated.
Kyle
1965 230sl
Download Attachment:[/b] 230sldatacard.jpg
97.51 KB
Re: My Data Card
« Reply #1 on: March 14, 2008, 22:51:39 »
Hey Kyle. One thing I was able to deduce from the top row -- sixth box ... 5 217 XXX means it was originally delivered to a Frankfurt, Germany dealership -- so yes it was (and is) a Euro-spec.
Klaus
Re: My Data Card
« Reply #2 on: March 15, 2008, 10:14:51 »
Look here:
www.sl113.org/wiki/pmwiki.php?n=DataCard.Start
According to the card, the car had a manual transmission, and was delivered ex factory without a radio.
Klaus
1969 280 SL
(edited to manual; previously went by description from Classic Center which listed it as automatic)
« Last Edit: March 16, 2008, 09:50:57 by Klaus »
Re: My Data Card
« Reply #3 on: March 15, 2008, 11:38:57 »
Ok. This has to be said -- Klaus -- fantastic job of the Data Info in the Technical Manual!  It's exactly the kind of resource we all have envisioned...
benzportland
Re: My Data Card
« Reply #4 on: March 15, 2008, 16:01:27 »
Thank you so much - this is an excellent resource! Yes I mis-stated before about the transmission, it originally had an automatic transmission.  I am wondering if automatics were very common for this year/model?
If there is any more you might be able to tell me about the car besides what is obvious from the data card that would be greatly appreciated.
Re: My Data Card
« Reply #5 on: March 15, 2008, 21:11:48 »
looking at the picture of the data card the ORIGINAL engine number shown is 127 981 10 007773
According the DataCard Info in the User manual, '10' (7th  & 8th digits) indicates left hand drive with manual transmission
Quote
The next two digits are the same as the center digits in the VIN:
             The seventh digit identifies
                                           1          left-hand drive
                                           2          right-hand drive
             The eighth digit identifies
                                           0          manual transmission
                                           2          automatic transmission
The last six digits are sequential by transmission type (i.e. separate for manual and automatic).
Unquote
My interpretation is that the car originally had a manual transmission and the new engine was from a car with manual transmission.
Re: My Data Card
« Reply #6 on: March 15, 2008, 22:06:03 »
I agree with Bob. I see no reason to think the car was ever an automatic. (It's manual right Kyle?). I think the classic center's translation of #422 is throwing us off. It is power steering but the automatic shift was 420. I don't see that on the card.
benzportland
Re: My Data Card
« Reply #7 on: March 15, 2008, 23:17:18 »
Hi James - yes it is a manual now, so apparently it looks like it always was manual.  When I bought the car I did not realize it did not have an engine originally used for the W113, but I am wondering if it makes much difference at this point too.
Re: My Data Card
« Reply #8 on: March 16, 2008, 07:15:37 »
this link http://www.sl113.org/data/show_table.asp?table_name=usr_option_codes shows the MB option codes
Re: My Data Card
« Reply #9 on: March 16, 2008, 23:18:05 »
Kyle,
Did you know that you can tell if your hard top is the original one for your car?  Look at the very bottom of this page where line 4 of the data/paint plate is described:
http://www.sl113.org/wiki/pmwiki.php?n=DataCard.BodyandPaintNumberPlate
It tells you what number you might find on various parts of your car, which would determine a "matching numbers" car.
Pagoda Technical Manual
1966 230SL
2006 C230 Sport Sedan
benzportland
Re: My Data Card
« Reply #10 on: March 17, 2008, 20:26:36 »
Thank you I will check that out, she's in the shop right now but will check ASAP.
Kyle,
1966 230SL
Re: My Data Card
« Reply #11 on: March 17, 2008, 20:40:00 »
Does the Date Card contain the key numbers for the ignition, doors, etc?
benzportland
Re: My Data Card
« Reply #12 on: March 17, 2008, 22:43:34 »
I've included a copy of the card on the initial post above, see link to open.  I am not very familiar with these cards but it appears to me the those spaces are blank.
Re: My Data Card
« Reply #13 on: March 18, 2008, 06:26:01 »
You will find that if you provided proof of ownership you would have a data card showing the key numbers.
Re: My Data Card
« Reply #14 on: March 19, 2008, 00:16:06 »
I emailed them with my VIN and they provided me the data card without any questions.
It arrived today and to my amazement it is showing that the car, delivered in March 1969, Sold in Scotland and imported into Australia about 10 years ago, came with a 5 speed gear box.  Its been changed to a four speed somewhere in its life unfortunately so I am now in the market for a 5 speed box if any one has one that they would like to sell!
Australia
69 280SL Manual
02 320ML
05 A200
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
