Author Topic: A second SL  (Read 4857 times)
mbzse
A second SL
« on: March 31, 2008, 04:40:33 »
I bought myself a second 250SL yesterday, a Swedish sold car. :)
Metallic green, black leather interior, 5-sp manual. It is a California coupe, i.e. with a rear bench seat and no soft top.
/Hans in Sweden
« Last Edit: March 08, 2009, 16:57:24 by mbzse »
/Hans S
Re: A second SL
« Reply #1 on: March 31, 2008, 05:06:13 »
I attach a couple of image
/Hans in Sweden
nice looking Car [:p]
enjoy!!!
« Last Edit: April 01, 2008, 01:40:28 by naj »
Ricardo
Re: A second SL
« Reply #2 on: March 31, 2008, 08:09:07 »
Hans
Yes looks quite nice. Is it 834 Moss Green Metallic? Unusual placement of the sideview mirrors. This one for the wife or the mistress  :D
Eryck
Re: A second SL
« Reply #3 on: March 31, 2008, 12:03:24 »
Congratulations. A second Pagoda is an important milestone.  Ricardo is right, the mirror placement is not correct. I've seen a fully restored car with the same placement - mis-informed garage??? But have fun and congrats.
1965 230 SL White Manual
Hong Kong
Re: A second SL
« Reply #4 on: March 31, 2008, 15:54:53 »
Congratulations Hans!
Does it need much work? And will you be looking to convert it to a soft-top?
68_white
  • USA, TX, Houston
Re: A second SL
« Reply #5 on: March 31, 2008, 22:20:52 »
For some mysterious reason, I cannot open the files.
Anyway, I could not resist the opportunity to buy a second 113 too. 1970, signal red, original condition, no rust, no accidents, all numbers match.
The previous owner repainted the car in the original color, a fair not great paint job.  Compression tested between 170 and 175 psi with 110k miles. Not bad, that got me to want it.
I got the data card from MB Classic, which basically shows that everything in the car is correct, except the radio. The data card shows code 519 (Grand Prix Radio USA), but the one in the car is Europa Stereo. Also, I cannot figure out if the antenna is supposed to be powered. The antenna in the car does not go up when the radio is turned on.  Thanks for any help.
HARRY
68_WHITE
HARRY
1970 280SL RED
2002 E430 SILVER
1996 911 BLUE
Re: A second SL
« Reply #6 on: April 01, 2008, 04:35:50 »
"Antenna does not go up."
When an automatic antenna is a do-it-yourself installation,the wiring can be misplaced.
Suggest you turn the radio on then try various swiches to see what happens. Of course you can always trace the wiring.
To raise the antenna in one car I know, you turn on the radio then open the driver's door! Antenna retracts the same way when the radio is off.
It's not a problem unless you decide to listen to the radio while the car is scooting down the highway.
I believe an auto antenna retacts to just about even with the car surface while a manual rod stops a few inches above the fender to give a gripping place. Also the top of an original manual antenna usually has a slot for the "Pull Up" key.
Richard M, NYC
« Last Edit: April 01, 2008, 04:40:15 by 280SL71 »
dwilli3038
Re: A second SL
« Reply #7 on: April 02, 2008, 05:52:11 »
Congrats!!!! Looks good and a 5 speed. You are indeed very fortunate
Daryl
'77 280SE
mbzse
Re: A second SL
« Reply #8 on: April 19, 2008, 17:08:03 »
Originally posted by Eryck
Congratulations. A second Pagoda is an important milestone.  Ricardo is right, the mirror placement is not correct. 1965 230 SL White Manual  Hong Kong
Yes, you are very much right in commenting about the placement of these outer side mirrors. The P O told me there were some non-stock mirrors on the car when he aquired it, he then bought two original M-B swan-neck mirrors, but decided to mount these in the already drilled holes left and right... hence the awkward position. Yes, I will rectify this for sure, it is on my list of "ToDo" for this vehicle :)
/Hans in Sweden
« Last Edit: April 19, 2008, 17:09:26 by mbzse »
/Hans S
Re: A second SL
« Reply #9 on: April 19, 2008, 18:07:30 »
Very nice indeed!  Same colour as my '65 230sl. I wish I had your 5-sp though... (mine is a 4-sp manual)
Congrats!
Waqas in Austin, Texas
