Author Topic: Front Wheel Well Splash Panel Color?  (Read 4713 times)
« on: April 10, 2008, 04:25:27 »
Hello All!
What is the current recommendation on what color the front wheel well splash guards should be?  I am referring to the removable panels...
I was planning on have them painted black, but as I read through our forum, there seems to be a mix of answers...  some say body color, others black...
What is the current thinking on what these were when the car left the factory?
Thanks :) !
« Last Edit: April 10, 2008, 04:26:05 by bpossel »
Re: Front Wheel Well Splash Panel Color?
« Reply #1 on: April 10, 2008, 13:52:07 »
I take it you mean the piece that is inside up near the top of the wheel well? I am not at home, so I can't go out and look exactly. Mine are not body color, but not really black either. More of grey/black. I do not believe they should be body color.
« Reply #2 on: April 10, 2008, 14:01:48 »
I've seen it both ways, so I don't think there's a right or wrong answer. (Actually, there is one way that's wrong. If you do side in black and one in body color, that would be wrong...)
« Reply #3 on: April 10, 2008, 17:49:58 »
Thanks Douglas and Johnny,
Good to know that either option is good.
Bonb
dseretakis
« Reply #4 on: April 10, 2008, 18:25:01 »
What color are the existing ones?  I know that this is a different car but since Jonny mentioned a black/grey I can recall that on my 73 220D they are painted anthracite grey and the car is white.
Dimitri
'71 280SL
doitwright
  • USA, IL, Willowbrook
« Reply #5 on: April 10, 2008, 18:47:20 »
I hope this will help.  If you go to Brian Peters website www.MotoringInvestments.com click on Mercedes, and look for the Blue Pagoda that was listed for $105,000.  When you go through the detailed photos, you will see what he did.  I know they went back later to paint the heavy shield on the underside of the trans that is supposed to match the body color.  Also, take a look at the 190SL restoration photos where he explains how they purposely let the paint overspray along the edges where it meets the underbody.  I see similarities with the blue Pagoda.
Frank Koronkiewicz
Willowbrook, Illinois
1970 280SL Light Ivory
Frank Koronkiewicz
