Author Topic: Drive-shaft centering spider maintenance?  (Read 6692 times)
« on: May 08, 2008, 20:26:49 »
Does anyone know if any maintenance is required in the drive-shaft centering spider? (#35 in the figure below)
It looks like it contains parts 36-39.  I have it out and I'm wondering if I should do anything to it besides re-packing with grease. It looks fine (tight ball, spring, etc).
By the way, what grease is best for the drive-shaft?  Can I use bearing grease here?
Thanks!
Waqas in Austin, Texas
« Last Edit: May 08, 2008, 20:30:21 by waqas »
Re: Drive-shaft centering spider maintenance?
« Reply #1 on: May 08, 2008, 21:33:17 »
Hello Waqas,
The only maintenance for the bushing is greasing it. A good synthetic grease is best these days. Do not overgrease. Grease on the rubber flex disc will decrease it's life!
« Reply #2 on: May 08, 2008, 23:05:04 »
Thanks Joe!
I'm in the midst of replacing my flex disc (finally!) and I thought I'd ask about this spider. Regarding letting grease get to the flex disc, I discovered that I was missing the seal #50, and had a very crusty o-ring seal between the spider and the shaft (both seals are supplied with my Jurid flex disc kit).
« Reply #3 on: May 09, 2008, 09:34:40 »
Were 36-39 used on other models? Does 39 (the C-clip) clip to the tranny tail piece?  What is 27?    Is it the bearing in the support collar?
« Last Edit: May 09, 2008, 09:47:48 by glennard »
« Reply #4 on: May 09, 2008, 10:12:12 »
I have these parts on mt 1970 280SL.
The c clip holds 36, 36 ,37 and 38 in flange 35.
27 is the center section of the mid shaft rubber drive shaft support bushing
« Reply #5 on: May 09, 2008, 10:18:20 »
Do 36, 37, 38 ride on the tranny tail piece?
« Last Edit: May 09, 2008, 10:18:55 by glennard »
« Reply #6 on: May 09, 2008, 11:30:51 »
Glenn,
From what I understand, you are correct. The rear transmission shaft rides in the ball #37, while the two bushings #36 keep the ball centered. The spring #38 keeps the ball under pressure, and the circlip #39 holds this entire assembly within the spider/flange. The forward grease nipple on the drive-shaft keeps this assembly lubricated.
« Reply #7 on: May 09, 2008, 11:58:19 »
Wagas' explanation is correct.
