Author Topic: co adjustment  (Read 4675 times)
noel
co adjustment
« on: May 09, 2008, 07:17:30 »
Hi can some one help me to adjust co% on 230sl 1969 ?
Re: co adjustment
« Reply #1 on: May 09, 2008, 07:47:39 »
Hello, Noel,
Welcome to the site.
Have a read thru the linkage tour above to make sure it is correctly adjusted before attempting to change the mixture settings.
http://index.php?topic=5003
Using the 'search' function, you can do a search on 'idle mixture' to find related threads.
230SL production stopped 66/early 67.
By 69, only 280 were being produced, so be sure which model Pagoda you have.
Hope this helps
merrill
Re: co adjustment
« Reply #2 on: May 09, 2008, 10:54:08 »
noel,
assuming you have a fuel injected sl
I agree with naj,  check your linkage set up first.
second, why do you think you need to adjust your co?
co% should be 3.5 - 4.5% at idle
and 4 - 6% at 1500 rpm.
first things first, let us know why
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
