Author Topic: DOOR HANDLES hole/no hole?  (Read 3613 times)
BaronYoungman
  • USA, IL, Joliet
  • Veronica...
« on: May 13, 2008, 13:35:14 »
See following pixs, I am getting ready for paint and notice one side has an odd shaped hole where the non-lock part of the handle fits.  On the other side it is filled in.  Which is correct? Am I missing a piece if I am suppose to have a hole in the door what does that end attach to?  Just the door? Or is there some other piece?  I have gaskets but they are flat.  Could someone shead some light.
Download Attachment: doorhole.jpg
69.39 KB
Download Attachment: doornohole.jpg
94.62 KB
Download Attachment: doorwithhandle.jpg
107.47 KB
Baron Youngman
1971 280 SL
1 car 15 boxes
Bob "Baron" Youngman
1965 220se coupe restomod
Re: DOOR HANDLES hole/no hole?
« Reply #1 on: May 13, 2008, 14:15:54 »
A hole is required to secure the front bolt of the lock handle.  The hole is not round.  Its hard to describe the shape of the hole.  It is designed so that the bolt head on the handle end can be inserted into a larger hole and then slid forward into a smaller hole to lock it in place.
« Reply #2 on: May 14, 2008, 14:24:28 »
If it is like the 111s---2 rubber gaskets, 2 bolts.  The front bolt is tightened in the slotted hole and slid to the rear of the car.  The rear bolt(allen head) in rear of the door pulls the handle to the rear also.
« Last Edit: May 14, 2008, 14:25:58 by glennard »
