Author Topic: Removing Air Condition  (Read 5174 times)
Anfinn
« on: May 15, 2008, 13:41:31 »
I have removed the AC unit from the cabin, and I am now considering removing the components from the engine compartment.
I have read the threads to find out what is involved, but I am left with a couple of questions, which I hope can be answered by someone who has carried out this already:
Is it possible to leave the water pump as is and just use one of its pullies that line up with the generator pulley(in the low non-ac position)?
Or is there some reason I can't see that makes it necessary to change to the short water pump?
I assume I have to fit a bracket to hold the geneator in the low position. Is the bracket sold by SLS the one? See att. photo.
Download Attachment: Gen bracket.jpg
49.37 KB
« Last Edit: May 15, 2008, 14:38:10 by 280SL71 »
Re: Removing Air Condition
« Reply #1 on: May 15, 2008, 14:40:51 »
The rear two belt grooves on an A/C are wider, 12.5mm for the compressor belts, the alternator when installed with the bracket shown will use a 9.5mm wide belt in the rear groove.
The narrow 9.5 milimeter belt if used in the wide groove of the A/C crank and fan pulleys will cause it to bottom out and not make proper contact with the tapered sides of the belt.
Look for a salvage 280S or SE front crank pulley, fan pulley and alternator bracket, from a motor with or without air conditioning, the fan belt usually 9,5 x 935mm runs in the rear grove. try to get as much of the ascociated nuts, bolts, studs, spacers and hardware as you can.
Sometimes the threaded holes in the block for the alternator bracket studs are drilled all the way to inside the crankcase, so make sure the studs used to install the bracket are not too long or they can come into contact with the crankshaft.
When I put the 127 motor back into my 230sl, I also removed the A/C compressor brackets, and moved the alternator back to position on the bottom of the block.
The 230 Kuehlmeister A/C uses a different system of belts and pulleys but the procedure to change it to non A/C would be about the same.
« Reply #2 on: May 15, 2008, 15:03:43 »
I left the A/C bracket in place and found belts to fit. This way everything else stays the same. I plan to re-install the A/C with a new compressor in the future.
