Author Topic: Injection pump fine tune  (Read 5646 times)
bernafm
« on: May 22, 2008, 04:01:58 »
I have a 230sl and I have rebuild all the engine (new pistons, seals, valves,...). I have installed correctly the injection pump according to haynes book. The car is running well, but I think I can improved it. It is the time to fine tune it.
All documents I have seen talk about the screew behind the pump, but I never saw a detailed procedure to do the right fine tune. Can someone tell me how to do it or get it?
Bernafm
Re: Injection pump fine tune
« Reply #1 on: May 22, 2008, 04:25:12 »
Hello, Bernafm,
Have a look at this linkage tour.
Having it correctly set up will help a lot to get a sweet running engine.
http://index.php?topic=5003
bernafm
« Reply #2 on: May 22, 2008, 04:43:15 »
thanks,
All the procedures regarding the linkage have been done, but what about CO level at low and high rpm, low and high load?. How do I check and fine tune it?
« Reply #3 on: May 22, 2008, 04:51:31 »
You can use the 'search' function on the top right of the screen to do a search on 'idle' or 'idle mixture'.
There are a few posts explaining how to adjust the mixture and CO at idle.
You have to get into the pump to change any other settings - not recommended!
Also see:
http://index.php?topic=5486
http://www.sl113.org/forums/topic.asp?ARCHIVE=true&TOPIC_ID=790
« Last Edit: May 23, 2008, 06:16:49 by naj »
